Installation fail (3.1(2))
Hi,<br>When we install unity - it fails when it has to run the script after the first installation part (after coppying the files). It says that it cannot connect to SQL (MSDE). We have loaded SP2 for it and it still fails. Any Ideas?<br>it says "setup was unable to configure default settings on system. you may continue the settup process and configure the system manually."<br>Werner<br><br>
Anonymous
N/A
Re: Installation fail (3.1(2))
Can you run the Syscheck utility & make sure it passes all the tests? It may provide more detail as to what the problem is.
Scott Morgan
Cisco Systems TAC
Anonymous
N/A
I have rolled back to Unity 3.02 and it worked without a problem on the same machine - same SQL settings. i will run the until and get back to you. Thanks.
Werner
84
