installation guide for a 7835 with Unity ??
I just got a new 7835 that I had planned to install Unity on,
and it came with a couple Unity OS disks (Windows) and
no real instructions. The server boots up and the SCSI RAID
drives have not even been set up.
Is there a set up disk like CallMgr to configure the basic system?
If not, is there a guide suggesting what should be done, what
dirvers to load, what partitions should be created etc?
Re: installation guide for a 7835 with Unity ??
Hey Paul.
Here is what I normally due for a blank 7835 Unity install.
1) Boot from Compaq SmartStart CD and configure the system partition, Drive setup (RAID 1).
2) I create a 8Gb partition for system, 4 Gb partition for log files and a 4Gb partition for data (mailstore, only if mailboxes are stored somewhere else. If they are going to be stored locally, like a POV system, I'll increase the data partition.)
If you need more info on going through the Compaq Smartstart, send me an email directly.
Thanks!
Matt Slaga
matt.slaga@us.didata.com
separating your store and log files in exchange 2000 is a great idea for hard disk input output perfromance and for fault tolerance however putting them on different partitions does nothing unless on they are on seperate physical disks.
103
