Hi all,
I installed the CTI Client Toolkit in my local machine. It contains different options like VB,VC++ and one customized HTML file to choose.
the HTML file inside the screen popup section, calling one ActiveX control called CTIClient32. But i found only CTIClient32.oca in the packet. Is that sufficient for the system or do we need to get CTIClient32.dll. If so, why do an error come when I try to click on "Answer" button inside the html page.
Thanks in Advance.
Jis
