01-26-2009 05:36 AM - edited 03-13-2019 06:01 PM
Hi, what should I need if i install a fresh new copy of Call Manager 4.0 ? I have a cloned server (not a 7800 MCS) and i am planning to start and study about call manager. Do you have any ebooks or any guidelines (how to's). I am trying to download a CCM but there is so many available and i am not familiar with the naming convention.
01-26-2009 07:11 AM
there are no downloads for fresh installs, you need physical media.
if you're going to start on this i'd recommend to start off with 6.x or 7.x as most users are moving that way and only some users are keeping 4.x versions. almost no one has 4.0(2a) if planning 4.x then go to 4.2(3) which is most similar to 6.x.
java
if this helps, please rate
01-26-2009 10:55 AM
You can check following things,
Check links..
http://www.cisco.com/en/US/products/sw/voicesw/ps556/index.html
For books you can check..
Cisco CallManager Fundamentals, Second Edition (Alexander, Pearce, Smith,
Whetten, ISBN# 1587051923)
Configuring CallManager and Unity: A Step-by-Step Guide (Bateman, ISBN# 1587051966
