Installing CCM on 7815 MCS
This is my first time with CCM and I got to implement a CCM 4.1 on 7815 MCS completely but I don't find any supported document to install that. I have CCO login. Can any body help me in getting installaion documents which should include hardware installation also.
Which OS does 7815 use?
1 REPLY
Hall of Fame Super Silver
Re: Installing CCM on 7815 MCS
When you purchased the CCM software it should have been for 7815 server either IBM or HP. It comes with hardware detaction disk which inspects your hardware and prompts you to put in the correct CDs/DVDs. One of the CDs is W2K server somthing like 2000.2.7 or 2000.4.1 or 2000.4.2 which is Cisco customized Windows 2000 server.Take a look at this istall document:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/install/instcall/cm413ins.htm
HTH, PLease rate all helpful posts!
Chris
107
