Community Member
Installing CCM on a Compaq DL320-G2 Pentium 4 2266MHz
I have built a server to the following specs and I get the error "You are not using Cisco approved HW" when installing. - There is a total of 1GB of memory in the server. Has anyone seen this issue before? Any help appreciated!
HP Part Number Description
289349-001 DL320R02 P2.26 512 A1 US
300678-B21 512 REG PC2100 2x256 ALL
230534-B21 40G 7.2K NHP ATA ALL
268494-B21 DL320/360 DVD/FLP CBN ALL
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure09186a0080107d79.html
Community Member
Re: Installing CCM on a Compaq DL320-G2 Pentium 4 2266MHz
What ver of OS/CM are you trying to install??
Check Bug CSCea22840 which states the same problem, but for IBM x340 servers.
It might help?
Community Member
Thanks for the response. Bug CSCea22840 is no help. I am running Windows 2000 5.00.2195 SP4
Community Member
CCM 3.3(2)
Community Member
Found this posting from another conversation, regarding a failed installation of 3.3(2) on a Dell server that may be helpful?
"Win-os-upgrade-2000.2.5 installs Windows 2000 Service Pack 4. Read the release notes for win-os-upgrade-2000.2.5. You cannot install any version of CCM v3.3.x with win-os-upgrade-2000.2.5 installed.
Before CCM v3.3.x installs, it checks to see if Windows 2000 Service Pack 3 and ONLY is installed.
This happened to me. Your only choice is to start from scratch and load win-os-upgrade-2000.2.4, CCM v3.3.x, then load win-os-upgrade-2000-2.5 and win-os-upgrade-2000-2-5-sr1."
103
