12-14-2000 08:53 AM - edited 03-12-2019 10:54 AM
I have a requirement where the client is using Call Manager 3.05 on a Cisco Catalyst 6000 with a FXS Analog Interface Module (for analog phones and fax machines), using Cisco IP phones 7960 using an 8 port T1/E1 PSTN module.<br>My question is :-<br>1. What type of integration is best with Unity on this configuration? I was thinking of using AVCiscoTSP with uOne ports.<br>2. With the FXS module on the Cisco unit, do I still need an SMDI integration on top of the first integration?<br>Is this FXS module for Cisco compatible with the Unity?<br><br>3. Is there any more detailed information that I can find besides the the dual switch integration guide and the cisco call manager integration document which I already have?<br><br>4. For the third party software, why do we need to have PC Anywhere and Norton Utilities in the system (besides their obvious functions of course), and is this a must?<br><br>Looking forward to your response <br><br>Thank you<br><br>
12-19-2000 04:34 AM
As for your first question, using AvCiscoTSP with Uone ports is the best move. This does not also require SMDI integration to be setup
we get all we need through the skinny protocol with CM that AvCiscoTSP is using.
Im not personally familiar with the FXS module (something that Im sure will be remedied in the new year)
if its just providing analog lines for fax ports and the like, theres no reason it cant be used in conjunction with Unity. If, for instance, you have analog fax lines coming into an analog fax port on the Unity server, that should be fine. Im just guessing, however, at what you have in mind
The 2.4.5 integration guide discusses the dual integration a bit, this may be what you already have, however. If not, youll want to get newer versions of those docs. The concept is very simple, however. You setup your Uone ports as normal and you also install analog voice cards (i.e. D41Es or D160s) in the Unity server. You plug analog lines into these boards that connect to another PBX. Both switches have their own switch configuration page in the Unity SA and you configure them as normal. Each user/handler can be associated with one or the other switch. Notification devices can be configured to be one or the other switch independently since in some cases youll want dialouts going out the analog PBX even if the subscriber is using an IP phone.
As for the 3rd party utilities
you can take Norton out back and bury it in the back yard for all I care. One of those things weve been shipping for a while that made sense early on but with Win2K its pretty pointless.
PcANYWHERE, on the other hand, is for our support folks (including myself) to call into your system via the modem or via a direct IP connection if available. If you have a problem with your box this is by far the fastest and easiest way for us to figure it out and get it taken care of. We do require this be on your box and if its not, you may have to wait longer for support. In general you dont want to ditch this
just leave the modem unplugged if youre worried about security
plug it in when you need it. If the modem is an issue, make sure we can get through your firewall when necessary. Weve even had sites have us call into a modem on another box and IP over to the Unity server. Were flexible, but getting remote control access to your server is essential to support a complex product with many 3rd party dependencies such as Unity.
Jeff Lindborg
Unity Product Architect
Active Voice
jlindborg@activevoice.com
http://members.home.net/jlindborg
