Intercluster between ccm 3.0(8) and 4.1(3)???
Did u know if i can configure an intercluster trunk between a 3.0(8) callmanager and a 4.1(3) callmanager???
That version is really old but l need these information ... thank for your help
  • Other Collaboration Voice and Video Subjects
Re: Intercluster between ccm 3.0(8) and 4.1(3)???
Intercluster trunk should work between those two versions but I think there are quite a few bugs so use at your own risk.
Ok, but.... there is no an option to add an intercluster trunk in the callmanager version 3.0(8), does anybody knows how to make these or i need to use a gatekeeper???
Add gateway
for device type, select h.323
for device protocol instead of h.225 , drop the box down for intercluster trunk.
Bronze
Did your ICT work as my customer plan to do ICT btwn 3.1 and 4.1
Thx
104
