Interface between Catalyst 6500 and P.B.X.
Which module part number should I use for cat 6509 to work as a voice gateway and interface with P.B.X. via E1 PRI port ?
Should I use WS-SVC-CMM-6E1 OR WS-X6608-E1 ? and What is the difference between these two part numbers ?
Mohamed Abdallah
1 REPLY
Re: Interface between Catalyst 6500 and P.B.X.
It depends on what software you run on the cat!
if you use catos then use the WS-X6608-E1
If you use IOS then the WS-SVC-CMM-6E1
The WS-SVC-CMM-6E1 is the newer module and will have a lot more options in the near future such as a FXS module to fit into the blade so it's probably the best option, but like I said it depends on your OS.
Paul
107
