Community Member
Interface needs to connect a Cisco 3640 with a PBX with a E1 connection
I need to know what cisco interfaces I need to connect two PBX Siemens with a Cisco 3640 using a E1 trunk between the cisco and the PBX.
Also if you know which IOS I need.
Rodrigo
1 REPLY
Community Member
Re: Interface needs to connect a Cisco 3640 with a PBX with a E1
Hi rodrigo.
The module that you require to carry out this connection is the NM-HDV-1E1-30E for one port e1 or the NM-HDV-2E1-30E for 2 e1, the version of IOS to should use a feature PLUS, since the version 12.1.(3) T, for these interfaces
101
