Internaional call drops
CallManager 3.3(3)Sr2 with a MGCP PRI MRP2
IP Phones could make local and NALD calls, but failed to make international calls. It is not related with T310 timeout as the T310 is configured as 60000ms.
It looks the CallManager disconnected calls after received a Call Progress with "Cause i = 0x829F - Normal, unspecified" as following, I think it was a carrier's issue but I couldn't find what the Cause "0x829F" exactly means.
MRP1#
Dec 19 15:53:58.737 EST: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x014F
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '6477220000'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x91, '01161284466000'
Plan:ISDN, Type:International
Dec 19 15:53:58.777 EST: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x814F
Dec 19 15:53:58.781 EST: ISDN Se1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x814F
Progress Ind i = 0x8488 - In-band info or appropriate now available
MRP1#
MRP1#
MRP1#
Dec 19 15:54:01.929 EST: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x014F
Cause i = 0x8090 - Normal call clearing
Dec 19 15:54:01.941 EST: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x814F
Dec 19 15:54:01.973 EST: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x014F
MRP1#
MRP1#
MRP1#
MRP1#
.Dec 19 15:54:37.340 EST: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0030
Cause i = 0x8590 - Normal call clearing
.Dec 19 15:54:37.392 EST: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8030
.Dec 19 15:54:37.424 EST: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0030
Any comments be very appreciated.
Re: Internaional call drops
Try to set the CallManager Service Parameter "Disable Alerting Progress Indicator" to True....
We had some issues with this, we had to disable this progressindicator from our telco.....
hope this helps
Sascha
Silver
I'm glad you appear to be trying to call the AsiaPAC TAC ...
My suspicion is that the called number has a leading 011 as the international access code , but the numbering type is also set as international -
Called Party Number i = 0x91, '01161284466000' Plan:ISDN, Type:International
Since the numbering type tells the exchange that the called number is an international number, the exchange will be trying to use a country code of 011, which is not correct.
To confirm this, set up the CM to strip off the leading 011 access code, so the called number that hits the ISDN has just the 6128446000 number.
The other option is to change the called numbering plan and type IE on the gateway config from CallManager/CallManager to unknown/unknown. This will then make the local exchange analyse the called number, so it sees the 011 and directs the call to the international gateway and the gateway then looks at the country code correctly.
It works after changed the called numbering plan and type IE on the gateway config from CallManager to unknown/unknown.
Thank you so much.
133
