international calls fail
I have a customer who has CM 3.33sp4a, H232 gateway with a T1 for LD. The dial pattern 9.011XXXXXXXXXXXX
and the following dial peer
dial-peer voice 9011 pots
destination-pattern 9011............
port 1/0:1
prefix 011
When the call gets placed it rings then a recording comes on call can't be completed.
When I do a SH VOICE CALL STAT on the router it shows
0x1C0C2 151D 0x81B2AE64 1/0:1.20 8/4 *0396980059 g711ulaw 0/9011
debug out showes that it can't find prefix for DP
Mar 1 19:59:55: //114540/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Mar 1 19:59:55: cannot find prefix for dp 9011 called number 9011390396980059
Mar 1 19:59:55: //114540/80A70910A201/CCAPI/cc_delete_call_entry: not incoming
entry
Mar 1 19:59:55: //114540/80A70910A201/CCAPI/cc_delete_call_entry: entry's incom
ing FALSE.
Mar 1 19:59:55: //114540/80A70910A201/CCAPI/cc_delete_call_entry: is_incoming i
s FALSE
Mar 1 19:59:55: //114540/80A70910A201/CCAPI/cc_delete_call_entry: Deleting prof
ileTable[0x81DE2598]
1 REPLY
Bronze
Re: international calls fail
I would first change the dial-peer number. Make it something in the 90-99 range. I know this can cause problems. Why don't you just use the route pattern in CCM and not make a specific dial-peer. It should pick up the default dial-peer that you have for the location.
Geoff
103
