IOS Problem
Dear All
Cisco CallManager System Version 4.0(1.82)
IOS Version:c3640-jsx-mz.122-15.T17.bin
GW#sh ccm-manager
MGCP Domain Name: GW
Priority Status Host
Primary Registering with CM 192.168.0.73
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:00:00 UTC Mar 1 1993 (elapsed time: 00:32:34)
Last MGCP traffic time: 00:29:12 UTC Mar 1 1993 (elapsed time: 00:03:21)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
Configuration Error History:
FAX mode: cisco
GW#debug ccm-manager
00:31:12: cmapp_mgr_process_timer: Time-out waiting for RSIP ACK from 192.168.0.73
00:31:12: cmapp_mgr_process_ev_active_host_failed: Active host 0 (192.168.0.73) failed
00:31:12: cmapp_mgr_check_hostlist: Active host is 0 (192.168.0.73)
00:31:12: cmapp_try_fallback(set_to_mode=ON)
00:31:12: cmapp_try_fallback: fallback is not configured
00:31:12: cmapp_host_fsm: Processing event REGISTRATION_NEEDED for host 0 (192.168.0.73) in state REGISTERING
00:31:12: cmapp_mgcp_send_rsip: ip_addr=192.168.0.73 port=1720 type=3
00:31:42: cmapp_mgr_process_timer: Time-out waiting for RSIP ACK from 192.168.0.73
00:31:42: cmapp_mgr_process_ev_active_host_failed: Active host 0 (192.168.0.73) failed
00:31:42: cmapp_mgr_check_hostlist: Active host is 0 (192.168.0.73)
00:31:42: cmapp_try_fallback(set_to_mode=ON)
00:31:42: cmapp_try_fallback: fallback is not configured
00:31:42: cmapp_host_fsm: Processing event REGISTRATION_NEEDED for host 0 (192.168.0.73) in state REGISTERING
00:31:42: cmapp_mgcp_send_rsip: ip_addr=192.168.0.73 port=1720 type=3
pls help in this case
thanks
Re: IOS Problem
Looks like the gateway is not registering to call manager for MGCP.
Can the gateway ping the Call Manager server at 192.168.0.73? and vice versa?
Does the call manager have a gateway with a MGCP domain name of "GW" listed? The domain name on the router/gateway and that configured in CCM must match.
Any event log errors on the call manager server? You may have device unregistered and/or transient connection attempts. If the device name is @GW then that usually indicates the gateway isn't configured in call manager or domain in ccm doesn't match what router/gateway is sending.
You don't have any firewalls/ACLs blocking MGCP traffic between this gateway and CCM?
Re: IOS Problem
don't have any filter...I used cross cable between the two CCM and GW
Re: IOS Problem
try to use mgcp bind ...
368
