Community Member
IOS Telephony Services 2.0 and Cisco 1760
Can anyone help me answer the following question?
Does the Cisco 1760 support IOS Telephony Services 2.0? If it doesn't, are there are any plans to be supported on the 1760 in the future?
Ron
Bronze
Re: IOS Telephony Services 2.0 and Cisco 1760
Hi Ron,
You mean 1750 ?
If you mean the 1750 the answer is yes.
Look at the following link :
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/ipkey2.htm
Mehmet
The information that I have is it is not supported yet, but it will be supported in the 12.2(4)yb which is suppose to FCS around March 25. The fcs dates are always subject to change.
Hope this helps,
-Mckee
145
