IOS translation-rule - need help
Sorry if this mail has been sent twice
I need to create a translation rule or voice translation-rule which allow 8[0-3].. to be translated in 0155448[0-3].. without creating a rule for 80.., 81..,82..and 83..
My problem is that
this work
translation-rule 1
rule 0 ^80 01554480
rule 1 ^81 01554481
rule 2 ^82 01554482
rule 3 ^83 01554483
but I need to create only 1 rule instead of 4 because rules are limited to 10 and my numbering plan doesn't go from 0 to 9 ( discontiguous numbering plan)
Example :
8100 call reach the IOS gateway and I want this number be translated in 0155448100 to be routed by the IOS gateway
Can you help me
Need your help as soon as possible
Thanks for all
Irene
Re: IOS translation-rule - need help
Should this work for you?
or do you have problems on matching 4-9 too??
tranlation-rule 1
rule 0 ^8. 0155448
Sascha
Hi Sascha,
Thanks for your answer but I don't want to match ^8.
meaning digit begining by 8 and like 81,82, 83,84,85,86,87,88 or 89. I want to match only 81,82,83 but not 84,85,86 etc...
I want to exclude 84,85 up to 89
Irene
Silver
If you use voice translation-rule, you can add 1-15 rules. That will give you some space to write this individual rules.
I am not sure if we can specify a range in translation-rule expressions.
using translation rule I can add only 10 rules and I need to add 23 because of the existing numbering Plan.
I don't know how to specifiy a range from [1-3] for example and I am not shure that it's possible too.
Irene
I don't know it this works but try it;
voice translation-rule 1 --thanks to pbarman..---
rule 1 /^8[0-3]/ /0155448/
Sascha
I'll test it tomorrow and give you a feed back
Hi Sascha,
I tested it and it doesn't work
Result
A1-GWT2#test voice translation-rule 1 82
Matched with rule 1
Original number: 82 Translated number: 0155448
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
this should probably work for you unless I'm not getting what you want. the \0 inserts the matched pattern (could use a '&' instead if you prefer)
rule 1 /^8[0-3]../ /015544\0/
hq#test voice translation-rule 1 8100
Matched with rule 1
Original number: 8100 Translated number: 0155448100
hq#test voice translation-rule 1 8200
Matched with rule 1
Original number: 8200 Translated number: 0155448200
hq#test voice translation-rule 1 8300
Matched with rule 1
Original number: 8300 Translated number: 0155448300
hq#test voice translation-rule 1 8400
8400 Didn't match with any of rules
ah super! I saw on my GW it works....
I was wondering how to put the matched digits back..
I couldn't find this documented....do you know where?
.....the voice translation-rule allows 15 rules...
so 4 seperate rules wouldn't matter I guess...???
glad I could help
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tvr/vrg_r1.htm#2036716
its the command ref for rule (voice translation-rule)
Thanks for your help
The voice-translation rule you gave on the forum matches exactly my need.
Irene
137
