Community Member
IP address problem wih ICD
OK I did a dumb thing. when I installed ICD initially I specified ip 10.235.0.7 but I decided later to used ip address 10.235.0.4. So I changed the ip address and the engine parameters. All the ports come up happy and working. I can call my app and it works.
My problem is this. When I attempt to install agent desktop via the install manager I get an error saying Process error 10.235.0.7 yada yada yada. I looked through some of the config files under the desktop_config directory and saw where my old address was specified and changed them. I also changed the old ip address where it was referenced in the registry. still getting the same error.
Can anyone tell me a way to get the ip address change to work?
1 REPLY
Bronze
Re: IP address problem wih ICD
Did you go into the TSP settings in Control Panel Modems? If not it may be defaulting to the install settings. Go into Control Panel > modems > advanced tab> and properties of all the TSP ports you have and make sure you have the correct CTI manager chosen.
Geoff
87
