IP Addressing with IP Phones and attached PC's
Can someone point me in the right direction with regards IP Addressing and IP Telephony? Scenario: IP Device (PC) attached to an IP Phone attached to a Catalyst Switch. Question. Do I have two IP and MAC addresses assigned to a single port on the Switch and how can I distinguish which one is the Phone or the PC? A URL explaining would be useful if possible.
Re: IP Addressing with IP Phones and attached PC's
When you daisy chain a pc off the IP phone switch, the phone's connection back to the switch is a 802.1q trunk, therefore the pc is on one subnet and the phone is on another. When you configure the port you enable trunking and set the native vlan # (data) and voice vlan #
this should get you started in the right direction
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00800d84c0.html
Are these steps the same for a 3524?
Also - in the documenation I notice it allows for classification by P or Q tags - is there a prefered approach if we the customer have none?
- ken
To explain I can give you an example:
2 Vlans:
One for Data (PC) and one for Voice (IP Phone & Call Manager), in this ex.
VLan for Data: VLAN 3 - network 10.10.25.0 mask 255.255.255.0
VLan for Voice:VLAN 2 - network 10.10.60.0 mask 255.255.255.0
Catalyst switch with IOS, ex 3524 PWR
Interface connect to IP phone
interface FastEthernet0/2
switchport trunk native vlan 3
switchport mode trunk
switchport voice vlan 2
switchport priority extend trust
Then you have to connect this switch to a sw Layer 3 or router. I can explain how to do it if you want.
MP
116
