IP Communicator help please
I want to know if IP Communicator can be implemented with a mail software like Microsoft Outlook. If the answer is no, please say me how can I implement this software with another Cisco software of IP telephony.
Thank you, Carlos.
1 ACCEPTED SOLUTION
Re: IP Communicator help please
Please take a look at the following document:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008017902d.shtml
If this solves your problem, please remember to rate the post.
Brandon
Is your question if Communicator and Outlook can run on the same machine or if they can be integrated? They can be run on the same machine. The only integration that I know of is the ability to dial from your Outlook contacts.
Hope this helps.
Brandon
Thank you I am interesting in the ability to dial from my Outlook contacts.
How it works?.
What I need to get this ability?
Brandon
97
