ip communicator issue w/ Vista
i have an issue with my ip com V2.1,
those are the caracteristics of my laptop:
HP Pavilion DV2735LA
Vista 64
speakers (Conexant High Definition Audio)
sound card interface SPDIF (Conexant High Definition Audio)
I tried w/ ip comm 7(0)2 and i had the same issue.
I was researching and i found that it could be a bug.
I attach the error and the bug.
What version i have to use to make it work?
Regards.
1 ACCEPTED SOLUTION
Re: ip communicator issue w/ Vista
Hi Amanda,
This is likely because Vista 64 bit is not supported.
You can look at this table here to find out what should work with IP Communicator 7.0:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cipc/7_0/english/release/notes/CIPC70_RN.html#wp49960
hth,
nick
Hi Amanda,
hth,
nick
oh..that's bad.. thanks a lot
regards.
149
