Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
IP Communicator kills network connection - not registering
Just trying to run IP communicator, but when running the software it kills complete network connectivity, the PC cannot even ping the gateway!
If I connect as follows, everything works:
PC ->7941-> Switch
If I connect directly, it doesnt work
PC -> Switch.
Switches are outsourced, and they run MARS, nothing in the switch logs.
interface FastEthernet4/0/47
description Data and Telephony host
power inline auto max 7700
switchport access vlan 497
switchport mode access
switchport voice vlan 500
switchport port-security maximum 5
switchport port-security aging time 5
switchport port-security aging type inactivity
spanning-tree portfast
FastEthernet4/0/47 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0023.abea.5ab3 (bia 0023.abea.5ab3)
Description: Data and Telephony host
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input 00:00:29, output 00:00:22, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 24170
Queueing strategy: fifo
Output queue: 0/40 (size/max)
16734076 packets input, 7010128110 bytes, 0 no buffer
Received 25166 broadcasts (74851 multicasts)
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 74851 multicast, 0 pause input
29449800 packets output, 11698729854 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
cs01>sh int fa4/0/47 sw
cs01>sh int fa4/0/47 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 497 (LEGACY-DATA-VLAN-497)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 500 (VOICE-VLAN-500)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Anonymous
N/A
Re: IP Communicator kills network connection - not registering
What version of CallManager with service release? Have you enable auto registration on the CallManager?
Version 6.01,
the softphones register perfectly when connected via VPN, or Wireless or daisy chanied with a hard phone, but not when directly connected to our outsources switch.
For anyone who cares, I have confirmed the problem is caused by CDP. When CDP is disabled on the PC's NIC, I no longer lose network connectivity. Now to find out why
resolved: BUG: CSCsm26277
*Mar 8 01:18:53.889 UTC: PSECURE: Install IP Phone 0016.d446.5d34 on interface FastEthernet0/4 on vlan 500
*Mar 8 01:18:53.889 UTC: PSECURE: Read:1891, Write:1892
*Mar 8 01:18:53.889 UTC: PSECURE: psecure_del_addr: Deleting secure MAC address 0016.d446.5d34 on port: Fa0/4
*Mar 8 01:18:53.889 UTC: PSECURE: psecure_del_addr: Delete dynamic secure address: 0016.d446.5d34
*Mar 8 01:18:53.889 UTC: PSECURE: swidb = FastEthernet0/4 mac_addr = 0016.d446.5d34 vlanid = 500
*Mar 8 01:18:53.889 UTC: PSECURE: Adding 0016.d446.5d34 as dynamic on port Fa0/4 for vlan 500
*Mar 8 01:18:53.889 UTC: PSECURE: Adding address vlan 500 0016.d446.5d34 to port-security
*Mar 8 01:18:53.889 UTC: PSECURE: Adding addresses to port-security sub block
*Mar 8 01:18:53.906 UTC: PSECURE: Read:1892, Write:1893
*Mar 8 01:18:54.174 UTC: PSECURE: Read:1893, Write:1894
*Mar 8 01:18:54.887 UTC: PSECURE: Install IP Phone 0016.d446.5d34 on interface FastEthernet0/4 on vlan 500
*Mar 8 01:18:54.887 UTC: PSECURE: Read:1894, Write:1895
*Mar 8 01:18:54.887 UTC: PSECURE: swidb = FastEthernet0/4 mac_addr = 0016.d446.5d34 vlanid = 500
*Mar 8 01:18:54.887 UTC: PSECURE: Adding 0016.d446.5d34 as dynamic on port Fa0/4 for vlan 500
*Mar 8 01:18:54.913 UTC: PSECURE: Read:1895, Write:1896
*Mar 8 01:18:55.894 UTC: PSECURE: Install IP Phone 0016.d446.5d34 on interface FastEthernet0/4 on vlan 500
*Mar 8 01:18:55.894 UTC: PSECURE: Read:1896, Write:1897
*Mar 8 01:18:55.894 UTC: PSECURE: swidb = FastEthernet0/4 mac_addr = 0016.d446.5d34 vlanid = 500
*Mar 8 01:18:55.894 UTC: PSECURE: Adding 0016.d446.5d34 as dynamic on port Fa0/4 for vlan 500
467
