Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IP Phone Address Book Synchronizer Problems
Hi guys..
I installed the Sync application in order to sync my address book with the IP Phone. When I type my username and password in the password tab of the synchronizer tool and also the CCM IP Address and TCP Port 80 I received an error saying:
Unable to login (userid) with configured password.
I know that the userid and passwd are ok because I can log into the CCMUser web page with them. Is there anything else I need to do in order to get this tool to work.
I'm using CCM 3.3(3)sr4
Thanks in advanced,
-Jose
Re: IP Phone Address Book Synchronizer Problems
Hi Jose ,
I have the same problem . I have opened a TAC case for the moment for this problem . Here is a sample of the answer :
"Hello Olivier,
Actually, TABSYNC will only synchronize Outlook when it is in "Internet Only" mode. This means if Outlook connects to an Exchange server it will not synchronize the addresses. Cisco does have another product that will synchronize the PAB if the user is using the Exchange server. That feature is bundled with the PA product. Otherwise, the user will have to export the addresses into the Microsoft Address Book for TABSYNC to synchronize to PAB.
PA 1.2 (Personal Assistant 1.2) and IP Phone Productivity Services provide the capability to synch with the exchange contact lists. "
I have tried also with an "internet mode" but it doesn't work . So when I have feedback , I will say it to you ...
Olivier
I also had to add the ccm to the host file on the pc to get this to work. It may be something else to try.
John
212
