IP Phone behavior (second call on IpPhone)
How to force an Ip Phone to stay on first call when a second call is received.
After few seconds the second call is highlighted and the softkey "Answer" appears.
Any way to configure this ?
Fred
Re: IP Phone behavior (second call on IpPhone)
You can disable second call feature at all, if you set "Busy trigger" to 1 in "line configuration settings".
Thanks for your answer, but it's not exactly what I want to do.
If I set "busy Triger" to 1 I'm only able to receive 1 call at a time.
What I would like to do is to be able to receive several calls but to have only the first one highlighted on phone.
Fred
Silver
On the Directory Number page, try setting the "Ring Setting (Phone Active)" to "Disabled"
Anup
115
作成コンテンツを作成するには してください
