Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IP Phone behind a 501 Pix loses connectivity
I have a couple of remote users using an IP Phone attached to a 501 Pix. My problem is that their phones losse connectivity with the callmanager very often.When it happens the vpn tunnel is active which makes me believe that the problem isn't related to the pixes.
Have anyone seen this problem before?
rafael
Bronze
Re: IP Phone behind a 501 Pix loses connectivity
the tunnel may be up but it is possible that the phones keepalive may be dropping or timing out. Can you confirm that there is no packet loss over the vpn tunnel.
Could you tell me how to do that?
Thanks.
112
