12-06-2001 06:55 AM - edited 03-12-2019 01:37 PM
I am trying to find out how to use my 7660 phone at home over my broadband connection. We have a Pix 525 as our Firewall and VPN. I would like to know if I need additional hardware or just changes in my config. Thanks in advance.
01-08-2002 06:47 AM
Can you send me a sample config of your 806 router? I'm trying to do this on the 827 but with no avail. Although it may be an issue on our PIX515 configs as well. Is there anything special needed there?
12-07-2001 06:23 PM
well your question is not specific, because there is not way you can plug in ip phone without not having any kind of call manager or keyswitch router.
regards
omair
12-08-2001 09:15 AM
The IP phone accesses the CallManager through a VPN tunnel back at the office. The DHCP server that the IP Phone uses to get it's address also needs DHCP option 150 set to the CallManager's ip address. It is possible to use one CallManager for several sites. Cisco calls this Centralized Call Processing. Our company only has about 300 phones and one CallManager can handle 2500 phones (current limit).
01-09-2002 02:37 PM
hi
has anybody tried this with checkpoint VPN...i was able to get to the Phone seeing the server but the TFTP kept timing out
01-17-2002 07:07 AM
We have tested the IP Phone 7960 (and also the Cisco IP Softphone) with a 803 Router (HomeOffice Solution, Problems here are the link costs)and with a Cisco 3002 Hardware Client (VPN Connection)as well, and it works fine.
01-30-2002 07:41 AM
Is it possible to get a copy of both configs from you? We have this working, but are experience various subtle problems. Would love to be able to compare configs to ensure we haven't left anything out.
Thanks.
01-31-2002 03:47 AM
Given that a secure tunnel is set up between two PIX firewalls over the Internet, and an IP phone is placed at one end and a Callmanager at the other, can anyone expand on what effect encrypting an IP phone call has on voice quality?
I always thought that runing voice through an IP sec tunnel had an effect on quality of voice because of the latency and delay introduced by the encryption-deencryption process. Is this no-longer true?
