IP phone not connecting
What we are trying to do is test remote users access
and VoIP. Are current setup is like this. We have a Cisco 831 connected
to the Concentrator 3030 via an VPN Tunnel. The 831 would be used at a
home office. Behind the 831 we have a PC and a VoIP phone (Non-Cisco).
When the phone registers with the Gatekeeper it uses the Private IP address
assigned by the 831, not the NAT'ed address. Now I have found documents on
Cisco's site that say there is an issue with h323 and NAT, but are fixed in
the latest IOS versions. I have upgraded to the latest on both the 831 and
the Gatekeeper. The gatekeeper is a 2621xm. The phone still registers
with the private address.
The IP phone is:
Polycom SoundPoint IP 400
REV 1.1.0 28-Jan-02
BootROM Rev 1.1.1 03-Jan-02
Can you help on thsi.
Silver
Re: IP phone not connecting
Bronze
If you have a "permanent" VPN tunnel up, why don't you address the inside private the same as your LAN so that call manager and the phone think they are at the same location? I have home users with Netscreen VPN boxes hooked up like that and they work just fine. Make sure you give out all the relevant options with the 831.
Geoff
272
