IP PHONE RESET ISSUE
Dear pros,
could you help on the below issue
When I try to reset the phone using the callmanager administration web page ip phone does not get reset
what could be the problem
ccm 4.1.3 running
swamy
Bronze
Re: IP PHONE RESET ISSUE
Swamy:
Does the phone show registered to a subscriber in CCMadmin? If so, check the ports that you have open to communicate to CCM on the network.
http://www.cisco.com/application/pdf/en/us/guest/products/ps5820/c1693/ccmigration_09186a00807217e1.pdf
Hope that helps.
Tom
Tom,
where can i check the port?
What cmd should i use?
in the pc prompt c: netstat -n ?
swamy
Bronze
Swamy:
From the switch or router enable mode:
switch# sho access-lists
will display the access lists for the switch
switch# sho ip interface
will display where the access lists are applied on the interfaces.
Check whether the ports CCM uses to communicate with the phones are blocked by an access list in any switch or router between the phone and the cluster. Remove any statements that block the communication on ports or interfaces used in the path.
Tom
sir,
i am shahid from kuwait.i have sipura anlog telephone adepter, model: SPA-2002 , MAC : 000E08FAC5EA and serial :88012HA14870. i forget my admin password.i can not broken that Admin password. i tried by useing ****73738# command to break it. but not break. please kindly help me about it. inform me how can i break it.
rgs,
shahid
from kuwait.
Bronze
Shahid:
The manufacturer's admin help for this product is located here:
http://www.sipura.com/Documents/SipuraSPAUserGuidev2.0.9.pdf
There is an informational item located on a vendor site that addresses this issue, too.
http://www.inphonex.com/support-center/index.php?x=&mod_id=2&id=57
Looks like you already tried the reset procedure, so I would call the support line for assistance if the above references will not resolve the issue.
214
