04-25-2008 04:50 PM - edited 03-13-2019 05:12 PM
HI,
I had Noticed that internet connection is too slow while using ciso ip phones (7940,7960) while when connected directly to the Switch it is fine, I had changed the ip phone with new one but still get same Problem.
I had CCM4.2, Cat6509, 3750 and 3560 switches installed.
Could any one help in this issue.
I also attache my switches Configuration
05-13-2008 04:53 AM
Does the problem only occur when making a call and browsing the internet at the same time?
Does pinging the default gateway reveal any difference when connected through phone or directly?
Have you checked for duplex/speed errors on the phone's PC interface?
Have you checked the WAN utilization when internet is slow.
05-13-2008 06:11 AM
Hi ciscomummiez
Thank you for your reply.
.The problem occurs even when no internet browsing and no call.
.Pinging to the default gateway does not show any differece.
.for duplex/speed i had tried all possible combinations but no luck.
.for the WAN utilization i checked the internet utlization is unchanged i mean it is stable.
I also had FWSM module installed on the switch and someone alse had had the configuration, does FWSM had any affect on this issue.
Thanks and best regards
