Community Member
IP Phone to IP Phone delay in Voice CM3.3(3)SR2
Currently running CM 3.3(3)SR2. Phone Load for 7960/40 P00305000300. Prior to upgrade we were running 3.3(2)SPC. All of a sudden we are having Voice delay from IP Phone to IP Phone. User will call phone A to phone B. Phone B will not hear phone A for the first 5 seconds or so. I've seen delay over PSTN but not internal. Possible phone load? Any thoughts. Thanks
Re: IP Phone to IP Phone delay in Voice CM3.3(3)SR2
that is the latest load out there for 7960/40 for 3.3.3. can you please turn on QRT key on the phone. and collect the logs for the selected phones. Is it for every phone?How often do you see it.What is the Gateway where the calls are coming from? What is the protocol? You see one way audio for 5 seconds in both directions? or just from one site.
Depending on what exactly you see, i could suggest some debugs.
thx
Please check all these stats.
thx
Community Member
Is there any update on this issue?
I have a client with similar issues occurring,
again inbound from the PSTN.
The difference is that we are using 3.3.(3)SR1
and we have 12.2(15)ZL code on the MRP.
Same Phone Load for 7940/60.
Gold
Are you absolutely certain that the phones updated to P00305000300? This sounds exactly like a bug that was present in P00305000100.
Community Member
Double checked, just in case, and under device
defaults for the 7940 and 7960, P00305000300 is
listed; and also under firmware load information,
CCM reports that all phones are using the default
load.
A full reload (pub+sub) may be providing a temporary fix for this issue, but we are staying tuned. . .
Bronze
Do you have the option "H323 FastStart Inbound" set to "true" in CCM service parameters? I had the same issue it is set to false by default.
this helped me,
geoff
Community Member
Yes, that parameter is set to true, though the
parameter default is false.
On a different note, the problem has not reemerged
since the full system reboot (Pub+Sub).
Community Member
Most of My customers are running version 3.3(3). Cisco has recenlty release service release 2 and 3. In fact, I cannot trake risk of applying those service release without testing. So I setup a lab for this. I install 3.3. Then I put the releases that cisco has launched and I am facing the same problem you are facing and thank god it is in lab environment. What is Happening that when you dial a local extension, the phone wait for the timer what we used to face in outside call befroe establishing the call to the next phone. It is funny that the call manager doesn't perform quick route look up and do the nearest match. I am still trying to find a solution. Did you resolve this issue?
Community Member
I have two Callmanager Clusters. Both had CM version 3.33sr2 but only one had this problem.
This problem was not there right there after the upgrade to sr2. After several weeks we had the delay the first time and then we had it more often.
At our maintenance at christmas I upgraded the cluster to sr3. After that we never had the delay.
I don't know if the problem was solved with sr3 or if it was just the reboot of the system.
But I would give sr3 a try - I have no problems with it.
Community Member
I had the problem again a few minutes ago. This time it was a call from IP-Phone to IP-Phone.
My colleague had the problem with a call from an ISDN phone.
So the problem was not solved wit sr3.
Community Member
A new phone load is available - P00305000400.
Might be worth a go.
213
