IP Phones and Nortel BPS 2000
Has anyone already rolled out Call Manager (more than 800 phones) on a LAN made of Nortel BPS 2000 and Nortel 8600 ?
How did you configure VLAN and QOS (did you configure a separate VLAN for voice ? if so, how ?). Did you connect PC behind the IP phones ?
Have you experienced specific issues ?
Thanks for help
Laurent AUZELY
Presales Engineer - Telindus France
Re: IP Phones and Nortel BPS 2000
use cisco equipment. It will make your life easier. Cisco switches have the ability to configure multiple vlans.
I'm convinced about this ! Thanks for the answer
The only concern is that the custumer has just invested in a brand new Nortel network (2000 ports) and is not willing to change it next month ! His request is now to roll out an IP Telephony solution on this network...
Laurent
180
