IP Phones not hearing a ring-back
The following link explains how to fix a problem where PSTN callers are not hearing a ring-back when calling an IP Phone.
http://www.cisco.com/warp/customer/788/AVVID/pstn_ip_ring.html
I have the opposite problem. My IP phones do not hear a ring-back when dialing through a gateway to our Lucent Definity PBX using an ISDN-PRI connection. Any ideas?
Re: IP Phones not hearing a ring-back
I can´t help, but i have a similar problem with 7960 via QSIG to a Siemens Hicom300E. When i call to the PBX i see only the text "Ring Out" but i can´t hear a ring-back tone. Via PSTN to Hicom i hear a ring-back on the IP Phone. I work with CCM 3.0(9), 3640 with ISDN BRI S/T and IOS 12.1.5(T). My config for the BRI is:
interface BRI1/0
no ip address
isdn switch-type basic-qsig
isdn overlap-receiving
isdn incoming-voice voice
isdn static-tei 0
voice-port 1/0/0
compand-type a-law
cptone DE
Maybe the same cause!
Martin
I had the same problem...here is the fix....
dial-peer voice 1 pots
destination-pattern 9T
progress_ind alert enable 8 <-----these are the fix
progress_ind progress enable 8<-----
progress_ind connect enable 8<-------
direct-inward-dial
port 2/0:23
I only have the progress_ind command available if I am configuring a VoIP dial-peer. I cannot enter these commands.
Thank you for your posting!
I try and it´s working.
In the pots config i see usually only the options progress and connect but i can enter the alert option.
Thank´s
Martin
Glad I could help!!!
Greetins Mr. Mike,
I our company we are facing a similar problem.
Wich we try to correct with the solution you gave in the past 26th of April.
Our problem is:
when callers from PSTN ask for redirection to a specific extension, the call is redirected but the PSTN caller doesn´t get ring-back tones!!!!
Clues???
Thanks in advance,
Rui André.
Unfortunately, it is working as expected. The IOS gateway is not able to play any tones once the DSP is already in a connected state. There was a fix put into CallManager so that when a transfer happens that it will tell the IOS gateway to play a tone to the PSTN side, but the IOS gateway fix to implement this is not yet completed. No word yet on when this will be available.
The long term fix for CallManager and IOS gateways in this scenario is for both to implement the H.450 Call Transfer feature, but that will take some time.
Note: the problem you describe does not happen with Skinny-based (and I believe MGCP-based) gateways, only with H.323 gateways such as IOS-based Cisco routers.
I had the same problem and it has been fixed. Don't know if you are still having it. It requires an upgrade to callmanager 3.0(10) and also an IOS upgrade to the gateway you are running. I am running the h.323 gateway on a 3661. Hope this helps. I would advise you to call TAC for assistance on the specific IOS for you gateway
816
