05-13-2003 01:48 PM - edited 03-12-2019 11:51 PM
Is anyone yet implemented the IP softphone on Citrix for multiple users. It is working but only for one user. Also is it possible to run ip softphone through Citrix over a dialup connection from home.
05-20-2003 08:21 AM
As far as I know Citrix is not supported application by Cisco IP soft phone. I am not sure how its working for you.
05-22-2003 11:23 AM
Yes It workes . I installed the program on citrix and than through client i can access the call manager and the lines on my soft phone. I can make the call and othe rparty can hear very well,but i have the problem at my end over the dialup.
05-30-2003 04:23 AM
How would you register the additional phones on the CCM? Wouldn't CCM prevent you from associating multiple phones with one MAC?
05-30-2003 07:31 AM
Can't we install the ip spftphone for each user. You don't need the MAC address for IP softphone. It is a virtual phone. Don't you think it should work that way.
