IP Telephony Design Info
I want to deploy Cisco IP telephony solutions with in best price.
I have done some research on this. I am not new in Cisco world but in IP Telephony I’m very new.
I want to design 150 to 300 users IP telephony solutions for this following is my design.
2 x Cisco 3845 & each have 2 x 8 Port ISDN BRI Modules and each have one Unity express enhanced module(NM-CUE-EC)with 100 mail users.
One IBM x346 single xeon processor with CM4.1-K9-7815.
Now I want to know that I have 2 voice gateway routers with unity module & only one CCM server.
Is both router simultaneously configure with CCM & work also backup for each other.
Means I have total 32 ISDN BRI ports & 200 Voice mail user support.
I need your feed back.
Bronze
Re: IP Telephony Design Info
do you have centralized callmanager solution?
are the gateways on the same location or in different locations?
assuming you have a single site:
Q: Is both router simultaneously configure with CCM & work also backup for each other.
A: yes, you have total 32 ISDN BRI ports
Q: & 200 Voice mail user support,
A: summary, you have 200 user support, but each CUE is independently from other. it means you havent a backup or redundancy of the Voicemails.
greetings
mehmet
Thanks for your response.
I want to use CCM (CM4.1-K9-7815) that support 300 users on IBX x 346 servers.
Can I use CM4.1-K9-7815 on IBM x346 server w/o any kind of problem like licensing & features set or some restriction?
2nd question for Cisco VOIP phone I need to purchase phone set & phone license.
If I used 3rd party VOIP phone so still I need to purchase phone license from Cisco.
Farhan
Bronze
Q: Can I use CM4.1-K9-7815 on IBM x346 server w/o any kind of problem like licensing & features set or some restriction?
A: yes, you can use it. all CCM licences and Features are the same on all platforms..
Q: 2nd question for Cisco VOIP phone I need to purchase phone set & phone license.
A: Yes
Q: If I used 3rd party VOIP phone so still I need to purchase phone license from Cisco.
A: I think no
greetings
mehmet
98
