IP Telephony: Extension Mobilityrestrict
hi all
i wish know how to restrict the user to log EM in some phones or one phone only,
for example: one user can only login at one phone.
Thx
1 ACCEPTED SOLUTION
Re: IP Telephony: Extension Mobilityrestrict
no, but the users will take the configuration from the particular site. there is no workaround to what you want (limit who can and who cannot log in a phone)
that would require the change of the whole way EM works right now. Reach you AM and ask if you can open a PER
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
unfortunately this cannot be done, you can only enable or disable EM on a per phone basis but not select who can and who cannnot log in
if it's an EM enabled phone anyone can log into it, if it's not enabled, no one can log
javalenc
java
hi, are you sure of that? have you another solution for this? that doesnt use of FAC,
unfortunately yes, i'm sure.
that would defeat the whole purpose on which EM is based: the ability to log on any phone and load your profile and preferences
the only things you configure on the phone are to subscribe it to the service and enable it for EM. that's all you get to configure on it. as i mentioned it's all or none, but not selectively.
unfortunately there is no WA for this. either you let any user or no user to use the phone.
FAC is for calls based on an numeric code, not for EM login logout, not sure why you mention it.
don't shoot the messenger =)
javalenc
java
Ok, thanks for the reply and answer, i wish explain the scenario:
users of office 1 should not login into office 2.
Both office has own Device Pool,Location,Region,extension, partition, etc. that`s the request.
have you considered device mobility??
please go thru the link:
Device Mobility
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/devmobil.html#wpmkr1043721
not sure if it would suit your needs
javalenc
java
hi,
the extension mobility is the solution implemented on the users, with device mobility i can restric the login into region o device pool?
if you want add me at msn eljose_lol@hotmail.com
javalenc
java
ok, thanks very much for the help, i hope keep your contact via msn or email, jramos@desca.com and msn eljose_lol@hotmail.com
153
