IP Trunking Avaya MultiVantage/Definity to Cisco CCM
Does anyone have a document on how to IP trunk between Cisco CallManager and an Avaya Definity with Prowler Ethernet IP card?
Re: IP Trunking Avaya MultiVantage/Definity to Cisco CCM
If Avaya supports H323, it should be possible to integrate this with the Call manager easily. Go through this url http://www.cisco.com/warp/public/788/AVVID/config_h323_ccm.html
You may have to check the definity documentation on how to route and register to the callmanager.
hi,
I have done that before. Its quite tricky and there are some features that will not work.
You might liek to contact me directly at norman_k_h_leong@apl.com
What you need to do is published in the Avaya document "How to configure an IP Trunk between an Avaya IP600 Communication Server and Cisco Call Manager - Issue 1.2" The document name is IP600-CM-2924.doc, dated 7/3/02.
These type of integration notes are available at the Avaya website:
http://www1.avaya.com/enterprise/resourcelibrary/applicationnotes/index.html
128
