01-09-2002 10:44 AM - edited 03-12-2019 01:58 PM
We have a IP/VC 3520 and I was wondering if it can be configured to run through the V.35 module into an external CSU and then into our PBX and out through the local PRI. We were looking for a less costly method then installing and maintaining 4 ISDN lines.
01-15-2002 02:00 PM
You should run that by your Cisco designer (SE). I couldnt find anything on CCO.
02-20-2002 10:32 PM
The V.35 modules on the 3520 can be interfaced with an external CSU or IMUX to run off a PBX. Note however that a single V.35 module can handle only one video gateway session at a time regardless of the number of B-channels youmay have available
