IPCC peripheral error codes received when trying to fire SUPERVISE_CALL_REQ
We tring to fire SUPERVISE_CALL_REQ from my CTI application as per ICM server message protocol 8.
We opening a supervisory session with CG, with
SERVICESMASK=150
EVENTSMASK=524287
STATUSMASK=1023
CALLMSGMASK=16777215
AGENTSTATE=1023
The CTI application is logged in on ACD in 'Not Ready' state and is configured on
ICM as Supervisor for all the Agents that the application is monitoring.
We are using CTI Server 4.6.2.
With the service mask value 150 when we fire supervisor request to Barge
into a call we get two specific peripheral error code related to
Supervisory barge-in , which change according to the values of Agent
ConnectionDeviceIDType.
When Agent's ConnectionDeviceIDType is 0 (which means, The ConnectionDeviceID value is stable over time (between calls)).
We are getting Agent ConnectionDeviceID same as Agent Extension Number, and in this case Peripheral Error Code is 13102
13102: PERERR_GW_E_THREADSUPERVISECALL_EXCEPTION_CONSULT
1st Level Text = 'JTAPI Gateway - Error on SUPERVISE operation - Exception'
2nd Level Text = 'Got an exception on a call to 'conference'(method
'DirectSupervisorBargeIn' in class ThreadSuperviseCall )'
3rd Level Text = ''
When Agent ConnectionDeviceIDType is 1 (which means, The
ConnectionDeviceID value is dynamic over time (between calls)).
We are getting Agent ConnectionDeviceID is 10 digit value generated from
ICM , and in this case Peripheral Error Code is 13113
PERERR_GW_E_THREADSUPERVISECALL_INVALID_AGENT_CONNECTION1
1st Level Text = 'JTAPI Gateway - Error on SUPERVISE operation - Bad
Connection ID'
2nd Level Text = 'The connection id in the agent object is invalid (method
'BargeInCall' class ThreadSuperviseCall)'
3rd Level Text = ''
These error we are getting from CG.
Could anyone point out in the right direction.
  • Other Collaboration Voice and Video Subjects
1 REPLY
Bronze
Re: IPCC peripheral error codes received when trying to fire SUP
The followiing troubleshooting documents should be useful to you.
Cisco IPCC Enterprise Edition
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Software:Cisco_IPCC_Enterprise_Edition&s=Verification_and_Troubleshooting
486
