IPMA Login Issue
I've just set up Cisco IP Manager Assistant (Cisco IPMA) on my CCM 3.3(2) box. The wizard ran fine, I've got my service parameters set, set up a manager and an assistant, restarted TomCat, and checked that everything was running. But when I installed the IMPA console on my laptop, and started it, I can't log in.
I get "System Error. Please contact Administrator." The trace for the IPMA console client has
**** Log started Fri Nov 14 11:42:28 EST 2003 ****
Index file exists. Reading
java.net.SocketException: Connection reset by peer: JVM_recv in socket input stream read
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.DataInputStream.read(Unknown Source)
at com.cisco.ma.service.client.protocol.Message.read(Message.java)
at com.cisco.ma.service.client.protocol.MessageInputStream.readMessage(MessageInputStream.java)
at com.cisco.ac.client.communication.ReceiveThread.run(ReceiveThread.java:30)
in the java log, and a lot of
206: Fri Nov 14 12:15:29 EST 2003 % ERROR!! Login failed: com.cisco.ac.common.ACException: Temperory failure, Please try again later
in the AC log.
I'm using the right password and login, we don't have AD integration ... could there be a port I need to open up on the firewall for this? Is that in the documentation? The CCM server is on a different VLAN.
TIA,
-m-
1 REPLY
Silver
Re: IPMA Login Issue
189
