IPMA Manager problem
Does anybody knows why the "http://<IPMA server>/ma/desktop/maLogin.jsp" sometimes does not work?
IPMA is working fine.
Also de Tomcat administration page
"http://<IPMA server>/manager/list" does not work.
Alex
Re: IPMA Manager problem
/manager/list is to restart tomcat as well as other apps dependent on Tomcat..
try restarting the tomcat service from services.msc and see if that helps!
The problem is that this web page and the Manager web page (for filter settings) does not work.
Thanks for your answer
Alex
I have installed CCM 5.04 recently, I setup Manager Assistant configuration, I only cannot 'Access Manager Configuration' from "http:///ma/desktop/maLogin.jsp" as it immediately closes the MSIE window. Is anything wrong with the Javascript from this page?
I found my error. It is vital to switch off pop-up windows blocking before opening the URL "http:///ma/desktop/maLogin.jsp", othervise the MSIE windows is closed before the manager configuration window opens!!
198
