Bronze
IPMA Problems
Hi all,
i have Promlems to assign an assistant to a manager in a CM 3.3 SPB environment. I have the following message when i try to assign an assistant to a Manager in the Corporate Directory.
"The page cannot be displayed
There is a problem with the page you are trying to reach and it cannot be displayed. "
What is wrong ?
thanks
mehmet
Re: IPMA Problems
Mehmet,
It sounds like you may have DCDirectory problems on your server. Can you view users under /CCMAdmin->Users->Global Directory? When you receive the error message above check the w3svc logs at c:\winnt\system32\logfiles\w3svc1 (times in GMT, not your local timezone). What is the error code and any further messages on that line? Are you integrated with DC Directory (default) or have you run the Customer DIrectory Plugin to integrate with Active Directory or Netscape Directory?
Bronze
Re: IPMA Problems
here is the Answer:
1.Can you view users under /CCMAdmin->Users->Global Directory?-->Yes
2. When you receive the error message above check the w3svc logs at c:\winnt\system32\logfiles\w3svc1 (times in GMT, not your local timezone). What is the error code and any further messages on that line? --------------
2003-03-14 14:25:53 192.168.7.201 Administrator XXX.XXX.7.201 80 GET /CCMAdmin/MAServiceConfig.asp userID=manager 200 0 Mozilla/4.0+(compatible;+MSIE+5.5;+Windows+NT+5.0)
2003-03-14 14:25:54 192.168.7.201 Administrator XXX.XXX.7.201 80 GET /CCMAdmin/MAmanagerconfig.asp mgr=manager&action=newMgr 302 0 Mozilla/4.0+(compatible;+MSIE+5.5;+Windows+NT+5.0)
2003-03-14 14:25:54 192.168.7.201 Administrator XXX.XXX.7.201 80 GET /CCMAdmin/MAmanagerconfig.asp action=insert&mgr=manager&status=doassign|234|800a1391|'lblmaErrorCreatingManagerObject'_is_undefined 500 0 Mozilla/4.0+(compatible;+MSIE+5.5;+Windows+NT+5.0)
3. Are you integrated with DC Directory (default) or have you run the Customer DIrectory Plugin to integrate with Active Directory or Netscape Directory?------->
Only DC Directory.
Mehmet
Re: IPMA Problems
Did you get resolution to your problem? I'm having the same issue....?!
Bronze
Re: IPMA Problems
no!!! and you:))
I think at the moment there is no solution for this issue.
let me know if you solved the problem:))
regards
mehmet
Re: IPMA Problems
Hello my name is Angel Violero.
I have the same problem, I think, could you get a solution?.
Thanks.
150
