03-10-2004 08:02 AM - edited 03-13-2019 04:12 AM
I have a problem with IPMA route point failing over to a backup callmanager when the primary fails.
Basically, i've setup cti server, cti backup server and ipma primary server and backup server to my publisher and subscriber reflectively. The route point is configured to be part of the device pool where publisher is a primary callmanager and subscriber is secondary. When the publisher fails, if I check the status of IPMA Route point , i can see that the ip address has changed to the subscribers address, but the status remains not registered.
Has anyone seen this before? Am i forgetting a setting somewhere?
Elena
03-26-2004 07:49 AM
check this bug - CSCin24844
03-26-2004 11:10 AM
Apparently there is another two that match:
'CSCea16459 IPMA fails to re-open the CTI route point'
CSCdy73590 Failover via CTI/TAPI fail when shutdown publisher or unplug network
