Community Member
IPPhoneMenu and QueryStringParam URI
I am having difficulty getting the QueryStringParam URI to work in my IPPhoneMenu service page. The XML appears to generate correctly, but the Parameter doesn't get appended to the URL that the phone requests.
The Menu Item looks like this:
<MenuItem>
<Name>Dolphin</Name>
<URL>queryStringParam:CliID=6177&act=2&Ext=5654</URL>
</MenuItem>
And the Softkey at the bottom is:
<SoftKeyItem>
<Name>Submit</Name>
<URL>http://10.1.230.10/ccmcip/inout.asp</URL>
<Position>1</Position>
</SoftKeyItem>
When I highlight the entry and then press the softkey, it does not append the parameter to the URL. I tried having only one Param in the URI and that didn't help.
I'm pretty sure that my syntax is correct. Can anyone see anything that I did wrong? Or has anyone actually made this work that has code they can share?
Seth.
1 REPLY
Community Member
Re: IPPhoneMenu and QueryStringParam URI
Never mind...
It appears that this is only supported in v3.3.
222
