Is it possible to connect ATA 186's & PBX ?
I have two sites connected between 805 routers. I have one ATA 186 in each site and want to connect it to a PBX, to allow to make calls between both sites. Is it possible ? Do it need any special configuration ?
Thanks a lot for your help.
Anacelia
1 REPLY
Re: Is it possible to connect ATA 186's & PBX ?
it would be possible but you would have to make sure that the pbx had some analog trunk cards that suppoer loop start. you can not hook the ata to a analog station since the ata and a analong station from the pbx are both ring generators and not ring listeners.
111
