You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Is it possible to have more than one SRST reference?
On the IP phones there are 5 CallManager entries - could we configure one of those to be a secondary SRST gateway? This would be in addition to the entry on the phone that says SRST gateway because I can't find anywhere in CCMadmin that would designate a second SRST gateway - so this would be a workaround,
if possible... or not?
Erik
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: Is it possible to have more than one SRST reference?
If you want to do that you have to add the IP phone network settings manually, and cannot use dhcp/tftp.
If you use dhcp/tftp, then you cannot add callmanager ip addresses on the phone manually. The phone will get it from the callmanager, and you can have only one srst reference.
266
