is it possible to make incoming call silent?
Hi, we have a phone (7975) configured to contain 4 extensions numbers of exentsion mobility (7601, 7602, 7603, 7604), 3 of the extensions was assigned to 3 different users loggin to 3 different phones(A: 7602, B: 7603, C: 7604). Currently when calls to any of the extension A, B, or C, the 7975 and one of the A, B, C will ring. Is it possible to make the 7975 silent (only flashing) when incoming call to any of the extension A, B, C, and other phones ringing?
for example, if incoming call to A, currently 7975 will ring, phone login with A will ring. is it possible: Phone A ring but 7975 silent but signal incoming calls to by flashing extesion line A?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: is it possible to make incoming call silent?
Hi Shu,
On the config for the 7975 change these settings for 7602, 7603 and 7604 (under Directory Number Configuration);
Line Settings for this Device
Ring Setting (Phone Idle) Flash Only
Ring Setting (Phone Active) Flash Only
Hope this helps!
Rob
1 REPLY
Hi Shu,
Hope this helps!
Rob
179
