Is the Catalyst 5500 considered a supported switch for IP Telephony?
admin_2
Level 3
Level 3
Because the 5500 does not support 2 queues for prioritizing voice over other traffic is it considered a non-supported IP Telophony switch?
Not applicable
If you want to deploy Ip telphony and
would like to have a very good quality out of it.
It is recommended to use a voice capable switch i.e a switch
than can at the least creat two vlans ( two queues). auxiliary (voice vlan) and normal data vlan.
Voice traffic are given a very high priority to data frame on the layer 2 device that supports voice.
You can use a c5500 100baseT switch but you cannot gurantee QOS at
layer 2. 100 base T is sill CSMA/CD so this might be a problem on a data
and voice mixed environement.
use cat 2924Xl's, cat4XXX , cat65XX etc.
