Community Member
Is there a GUI application to monitor VoIP QOS?
I have a QOS policy map on a link to prioritize voice data and voice control packets. To find out if this policy map is working correctly I do a 'show policy-map int f0/0' and watch the counters. Is there a cleaner/better way to monitor QOS then to look at counters at the command line?
1 REPLY
Community Member
Re: Is there a GUI application to monitor VoIP QOS?
HI,
You can add Qos Device Manager into flash depending on the router platform you have. QDM is a bit like Pix Device Manager, and allows the graphing etc of pre and post policy bit rates etc. The graph have to be set up each time you run QDM, but it gives quite a good view of your policies.
Bill
116
