You can setup the router to collect accounting record for H323
connection using aaa. This can be sent as CDR records to a radius
or syslog server for reviewing.
Here is a sample config.
service timestamps log datetime msec localtime
aaa new-model
aaa authentication login default none
aaa accounting connection h323 start-stop radius
gw-accounting syslog
logging 10.64.6.250
ntp server 10.10.10.58
You can use no logging console to disable cdr logs to console as they may be quite disturbing
if you have lot of active calls whiole working from console.
This information would show you called and callilng station id, number and connection time.
router#
!--- The following output is for the forward call leg
Jun 18 11:15:02.867: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId BA55719E
F8C10015 0 1B1E08, SetupTime 11:14:39.367 UTC Mon
Jun 18 2001, PeerAddress 68575, PeerSubAddress , DisconnectCause 10 , DisconnectText
normal call clearing., ConnectTime 11:14:49.707 UTC Mon
Jun 18 2001, DisconnectTime 11:15:02.867 UTC Mon Jun 18 2001, CallOrigin 2,
ChargedUnits 0, InfoType 2, TransmitPackets 1509, TransmitBytes 102600,
ReceivePackets 1510, ReceiveBytes 138920
