is there a way to record the call
I want to know , if this possible for the administrator to record a call ?
Re: is there a way to record the call
I don't know of a way. That does not mean there is not I just have not heard of that being done. Not sure if there are any 3rd party apps to do this or not.
Thank you,
-Mckee
If you asking if you can record a CallManager phone call the answer is yes, you will have to use a 3rd party app.
I only know of the following product but Im sure there are others:-
http://www.eyretel.com/flash/index.htm
Also I think Performance Solutions do something like this. Or just install IPCC and a monitor server 8-)
If you are using Unity you should be able to conference in directly to a voicemail box that has no greeting and is set to record indefinitely.
I guess the user would have to initiate this, not the admin
Silver
Hi, i would recommend you to check out www.nice.com ,
they have really great recording solutions.
If you want to termibnate a call that originate or terminate at your PC by using any type PC2Phone application or CIsco Softphone then you can download a very good shareware which records all the audio signaling before they been processed by the sound card.
The link: http://www.highcriteria.com/productfr.htm#prod_TR
P.s. The product called TotalRecord
144
