ISDN BRI problem
Hi all,
I have connected my Cisco 2811 router to PBX via isdn bri, the problem is that i receive calls from remote branches, but when i try to call i receive a busy singal from router,what can cause this.
Thx in advance...
Silver
Re: ISDN BRI problem
What PBX are you using?
You would have to post your config for more help.
I would also suggest capturing the output from "debug isdn q931" command while attempting an outbound call and posting that also. (assuming you are using H323)
How is your PBX setup? does it require an access code on that BRI trunk?
Cheers,
Tim.
i am using siemens hipath 3300 series pbx.
My config is :
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn tei-negotiation preserve
isdn layer1-emulate network
isdn incoming-voice voice
isdn static-tei 0
isdn skipsend-idverify
SHOW ISDN STATUS:
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
debug isdn q931:
4d01h: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '122'
Plan:ISDN, Type:Unknown
4d01h: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
4d01h: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8290 - Normal call clearing
4d01h: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
4d01h: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
second call attempt:
Standard = CCITT
Channel ID i = 0x83
Calling Party Number i = 0x0180, '124'
4d01h: mbrd_e1t1_vic_connect: setup failed
4d01h: flex_dsprm_tdm_xconn: voice-port(0/0/0), dsp_channel(/0/4/0)
Channel ID i = 0x89
Silver
What about your dial peer config?
Does your PBX require an access code on that trunk?
Cheers,
Tim
dial-peer voice 10 voip
description HO & PR BRANCH
destination-pattern 10...
translate-outgoing calling 1
session target ipv4:10.0.4.252
dial-peer voice 71 pots
destination-pattern 71...
direct-inward-dial
port 0/0
forward-digits 3
NO pbx does not requrire access code?
338
