Community Member
ISDN Call from PSTN return to PSTN !!!
Hi, in configuration below I have problem because when CallManager ( is unreachable or the specyfic called number (DN) 3001.... is unconfigured on the CallManager the call go back to PSTN and the circle occures as long as the free B-channles ale available. This is confusing. How to block and terminate the call that came from PSTN not to go back to PSTN. Is something like "NULL" dial-peer which terminate configured calls and sends back disconnect code like "unassigned number or something like this".
dial-peer voice 100 pots
destination-pattern .T
port 1/0/0
forward-digits all
dial-peer voice 1 voip
destination-pattern 3001[123456]..
voice-class codec 1
session target ipv4:
no vad
Any suggestions
Re: ISDN Call from PSTN return to PSTN !!!
Change the destination pattern on the POST dial peer to be something more specfic than just .T - when the call fails on the VOIP dial peer, the router decides the .T is a close enough match so the call gets hairpinned back out. Best thing is configure the CM to leave the leading access code (eg , 0 or 9) on the called number and make the outgoing POTS dial peer use this as the destination pattern.
Community Member
you can make a translation pattern in callmanager that would match number
3001[1-6]xx translate this number to a unused extension number say 1234 or what ever fits your dial plan. then create a cti route point or a dummy phone. give it extension 1234 set all the forwards to forward to you voice mail. then create a new voice mail box 1234 set it to not take a message just play a greatting and hang up. then record a creating that say you have reached a number that is not in service or what ever you want to say.
hope this helps
